List of Events
Page and Master Events List
Mouse
Page Click or Tap: When the page is clicked or tapped
Page Double Click or Double Tap: When the page is double-clicked or double-tapped
Page Context Menu (Right Click): When the context menu is triggered on the page, either by right-clicking or another method
Page Mouse Move: Fires continuously as the mouse cursor is moved around the page
Keyboard
Page Key Down: When a keyboard key is pressed
Page Key Up: When a keyboard key is released (after being pressed)
Page
Window Resized: When the browser window is resized (also fires when the page first loads, after Page Loaded)
Page Loaded: When the page first loads in the web browser
Adaptive View Changed: When the current adaptive view changes due to one of the following:
- the browser window is resized
- the view is set with the Set Adaptive View action
- a new view is selected in the Adaptive Views dropdown in the prototype player
Window Scrolled Up: When the page is scrolled up
Window Scrolled Down: When the page is scrolled down
Window Scrolled: When the page is scrolled in any direction
Widget Events List
All Widgets
Mouse
Click or Tap: When the widget is clicked or tapped
Double Click or Double Tap: When the widget is double-clicked or double-tapped
Context Menu (Right Click): When the context menu is triggered on the widget, either by right-clicking or another method
Mouse Button Down: When the widget is clicked, while the mouse button is pressed down
Mouse Button Up: When the widget is clicked, upon the mouse button being released
Mouse Move: Fires continuously as the mouse cursor is moved over the widget
Mouse Enter: When the mouse cursor enters the area over the widget
Mouse Exit: When the mouse cursor exits the area over the widget
Mouse Hover: When the mouse cursor hovers over the widget for one second
Long Click: When the mouse button is held down on the widget for one second
Keyboard
Key Down: When a keyboard key is pressed while the widget has browser focus
Key Up: When a keyboard key is released (after being pressed down) while the widget has browser focus
Widget
Moved: When the widget is moved by a Move action
Rotated: When the widget is rotated by a Rotate action
Resized: When the widget's size is changed by a Set Size action
Shown: When the widget is shown by a Show or Toggle Visibility action
Hidden: When the widget is hidden by a Hide or Toggle Visibility action
Got Focus: When the widget gets browser focus by being clicked or tabbed to, or via a Focus action
Lost Focus: When the widget loses browser focus by being clicked or tabbed away from, or via a Focus action
Selected: When the widget is set to its selected state with a Set Selected action or when a checkbox or radio button is clicked
Unselected: When the widget is set to its unselected state with a Set Selected action or when a checkbox or radio button is clicked
Selected or Unselected: When the widget's selected state changes due to a Set Selected action or when a checkbox or radio button is clicked
Loaded: When the widget initially loads in the web browser (fires after Page Loaded)
Droplists and List Boxes Only
Text Fields and Text Areas Only
- Text Changed: When the text on the text field or text area changes, either by a user typing in it or via the Set Text action
Dynamic Panels Only
Gesture
Swiped Left: When the dynamic panel is swiped from right to left
Swiped Right: When the dynamic panel is swiped from left to right
Swiped Up: When the dynamic panel is swiped from bottom to top
Swiped Down: When the dynamic panel is swiped from top to bottom
Dynamic Panel
Panel State Changed: When the dynamic panel's state is changed with the Set Panel State action
Drag Started: When you begin to drag the dynamic panel
Drag Dropped: When you stop dragging the dynamic panel (fires when the mouse button is released, not when it stops moving)
Dragged: Fires continuously while the dynamic panel is being dragged
Scrolled Up: When the dynamic panel is scrolled up
Scrolled Down: When the dynamic panel is scrolled down
Scrolled: When the dynamic panel is scrolled in any direction
